Closed Solved
What kind of power supply and video card do i need
im planning on getting a HP ENVY H8 until i learned that the graphics card is crap on it, and to get a better one i need a better power supply and card. can anyone find me some compatible ones that will work for the computer, was hoping to get a gt 640, or a gtx 650, but not sure if it will fit in computer.
3 answers Last reply Best Answer
More about what kind power supply video card need
  1. Best answer
    Welcome to Tom's Hardware Forums,
    Although upgrading those can be done through HP's website here http://www.shopping.hp.com/en_US/home-office/-/products/Desktops/HP-ENVY-All-in-One/C1U69AV , you can custom order from them, you can also do much better (price wise) by upgrading on your own.
    If upgrading to a GT640, the included 300W power supply should be adequate. An upgrade to GTX650 and I will recommend a 400W or greater PSU for that.
    Lets see what we can do...
    EVGA 02G-P4-2643-KR GeForce GT 640 for $96 with shipping, HP wants $170, $70 savings
    or for the GTX650 upgrade
    Galaxy 65NGH8DL7AXX GeForce GTX 650 for $105 with shipping, HP doesn't offer that card. A power supply for the GTX650, I would recommend something like this
    CORSAIR Builder Series CX430 430W for $46 shipping included, HP wants $100 to upgrade to a 600W (for a GTX660 which they do offer)
    The graphics cards linked are representitive samples of what is available. The NewEgg links are used for descriptive purposes only (although I do shop from them)
    Hope it helps
  2. The GT440 isn't much of a card for $100 btw.
    - Better off with a Radeon HD7750 >= 850MHz.
    The original ones can still be found that don't have the requirement of a 6-pin PCIe power connector and they'll work with a lower grade power supply unit.
    They offer the HD7770, so I'll use that for comparison:
    - http://www.hwcompare.com/11912/geforce-gt-440-3gb-vs-radeon-hd-7770/
    But after reading the reviews I can't say I recommend it...
    - http://scottdbowen.id.au/hp/HP%20ENVY%20h8-1420t.png
    - The other reviews are mostly good or neutral, but it appears that they don't upgrade the PSU when you order it with a 'top of the line' video card, even though the cards are listed as supported.
    Over USD$2,000 for a decent configuration... you're kidding me, right?
    - http://scottdbowen.id.au/hp/Over%202%20grand%20-%20You%27re%20kidding%20me!.png
    - I cannot recommend this machine for the life of me.
    They also let people buy it with Windows 8 (32-bit) even though the base configuration is 8GB RAM.
    - That's piss poor QA demonstrated right there.
    - It won't be able to use half the RAM it ships with if people do that (and that is the default, which makes it even worse!).
    On a side note, the build quality of the HP ENVY LAPTOPS is much better!
    - They might not have the 3D grunt you're after though.
    - I can, and do, recommend HP/Compaq laptops.
  3. Best answer selected by thewtfguy.
Power Supplies Hewlett Packard Graphics Cards Computers Components Product
