Hate HT? No, I don't hate it at all. It doesn't like drivers and software that want to see a single CPU, that's all. Yes, it does cause instability with those few drivers and software programs. And yes, there are bound to be work around.
I use XP Home and besides, I can select single CPU in BIOS as well. The problem isn't a showstopper but it is still interesting to define the exact issues and solve them. This is a hobby after all.
To change the rules with a new CPU and then say that all the older programs or drivers that worked with single CPU's and don't with HT turned on are broken is silly. They met the old rules, and are as such not broken. They also work fine with AMD CPU's and about any other (Cyrix) even older CPU's. This doesn't say HT technology is "BAD" and you can't run around and say every non-compliant driver / program is also bad written BEFORE HT even existed.
All sort of drivers needed to be redone for XP as an example, and much older hardware was ditched due to lack of support. Was this XP's "fault"?. Well, it depends on how realistic you are. It is from an absolute sense, and isn't from a continued technology sense. Either way, a solution could exist with new drivers or revisions to software.
I am simply trying to find the driver or revisions to make it work. There is enough hate being managed without my help.
Admitting that a problem exists is the first step towards a solution. Some driver or software is the problem and once identified is there a solution?
My hunch, It's the modem driver and not the actual program itself.
