Ram and graphics card help
Last response: in Systems
July 30, 2012 8:26:38 PM
Hi all, thanks for your time.
I have bought this motherboard (GA-EX58-UD5) http://www.gigabyte.com/products/product-page.aspx?pid=...
and i am fitting an i7-920 im planning on using either a GeForce GTX 460 or a Radeon HD 5850 with the thoughts of adding a second card later on what are yhour thoughts on this set up.
My main question though is about ram, is it better to get 3x2gb ram cards 6x1gb or 2x4g or more ram?
More about : ram graphics card
July 30, 2012 8:28:49 PM
Get 2x4GB ram sticks, therefore you can upgrade when you need.
if money permits upgrade your single card
July 30, 2012 8:39:08 PM
What should i upgrade it too?
July 30, 2012 8:41:07 PM
How much are you willing to spend?
July 30, 2012 8:50:08 PM
how about the gtx 470 or radeon hd 6950?
July 30, 2012 9:00:06 PM
Ok ille get the 6950. What about the mhz on the memory the motherboard specs says it supports 2100+ should i go for that or stick with 1600?
July 30, 2012 9:06:47 PM
go with 1600 you will not see much to any performance increase.
July 30, 2012 9:10:28 PM
Ok, thank you for the help.
