Cyberpower custom PC build ~2000 (including monitor)
CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit [+19]
CARE2: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System [+19]
CAS: NZXT Switch 810 Hybird Full Tower Gaming Case w/ Dual 140MM Pivot Fan Slots and Front USB 3.0 (White Color [+0])
CASUPGRADE: None
CD: Sony 24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive [-32] (BLACK COLOR)
CD2: None
COOLANT: High-Performance Coolant powered by Koolance [+19] (Clear Color)
CPU: Intel® Core™ i5-3570K 3.40 GHz 6MB Intel Smart Cache LGA1155 (All Venom OC Certified) [-114]
CS_FAN: Default case fans
ENGRAVING: None
FA_HDD: None
FAN: CyberPower Xtreme Hydro Liquid Cooling Kit 360MM w/ Triple Fan(CPU & GPU Liquid Cool Capable, Extreme Overclocking Performance + Extreme Silent at 18dBA) [+30]
FLASHMEDIA: INTERNAL 12in1 Flash Media Reader/Writer (SILVER COLOR [+0])
FREEBIE_CS: NZXT Sentry Mix Fan Controller w/ Six 50W Channels & Five LED Color Switches [+0]
FREEBIE_CU1: FREE! Tribes: Ascend Promo Pack ($60 value) [+0]
GLASSES: None
HDD: 128 GB OCZ Vertex 4 SATA-III 6.0Gb/s - 535 MB/s Read & 200 MB/s Write [-45] (128GB x 2 (256GB Capacity) Raid 0 Extreme Performance [+63])
HDD2: None [-82]
IEEE_CARD: None
IUSB: Built-in USB 2.0 Ports
KEYBOARD: AZZA Multimedia USB Gaming Keyboard
MB_SRT: None
MEMORY: 8GB (4GBx2) DDR3/1600MHz Dual Channel Memory [-52] (G.SKILL Ripjaws X [+10])
MONITOR: 24" Widescreen 1920x1080 ASUS VS247H-P LCD [+157]
MONITOR2: None
MONITOR3: None
MOTHERBOARD: [CrossFireX/SLI] ASRock Z77 Extreme4 Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Lucid Virtu MVP, XFast Technologies, 7.1 HD Audio, GbLAN, 3x PCIe x16 (2 Gen3, 1 Gen2), 2x PCIe x1 & 2 PCI (All Venom OC Certified) [+43]
MOUSE: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK: Onboard Gigabit LAN Network
OS: None - FORMAT HARD DRIVE ONLY [-83]
OVERCLOCK: Extreme OC (Extreme Overclock 20% or more)
POWERSUPPLY: 1,000 Watts - Cooler Master Silent Pro Gold 80 Plus Power Supply ( 80 Plus Gold) [+49]
RESERVOIR: None
RUSH: RUSH!!! READY TO SHIP IN 3 BUSINESS DAYS [+69]
SERVICE: STANDARD WARRANTY: 3-YEAR LIMITED WARRANTY PLUS LIFE-TIME TECHNICAL SUPPORT
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
TEMP: None
TUNING: None
TVRC: None
USB: None
USBFLASH: None
USBHD: None
USBX: None
VIDEO: EVGA Liquid Cooling NVIDIA GTX Series PCIe Video [+179] (EVGA Liquid Cooling NVIDIA GTX 680 Hydro Copper 2GB VRAM [+30])
VIDEO2: None
VIDEO3: None
WNC: None
Total comes to $2,000.
Do you guys have any suggestions or upgrades or things I should change? I know i'm spending extra money on water cooling but that's definitely something I want.
5 answers Last reply
More about cyberpower custom build 2000 including monitor
  1. I would toss the 12 in 1 reader. it takes up a whole 5.25 bay, is cheap looking, and is problematic at best. a usb one on newegg costs $6. go with that.
    more importantly, i would not buy the monitor from CP. its more expensive than newegg AND then on top of that they charge $25 for shipping. go on newegg, sign up for the promo emails (they come almost daily). on each one there are multiple monitor choices. i got the same exact one CP offers 24" ASUS for $157 + $25 shipping on newegg for $129 (free shipping, no taxes).
    I would probably also add MAX DEFAULT CASE FANS +9.
    1k watts is way overkill. i would get the Corsair TX850. its better...
  2. Thanks
  3. I can't really change the power supply up very much. Nothing lower than 1,000W is an option. The HX1050 is an extra 91$
  4. Quote:
    wo wo wo.... dont buy a prebuilt computer, build it yourself, for 2000$ i can quickly make you a PC that will outperform that one in EVERY way...besides, you are not getting a very efficient watercooling system, i can make you a custom watercooling kit that will blow that one, let me know if you are interested.
    PS: if you were thinking about buying a prebuilt because building a PC is "hard" you are wrong... its not hard at all its VEEEERY easy and fun, i have a Quadsli GTX 680 watercooled with a i7 3960x with dual 560mm rads and it was VERY easy to build (and fun too :D)
    I cancelled my order and re-ordered it.
    For $1,770 shipped I got:
    NZXT Switch 810 Gun metal case
    Nvidia 680 Hydro Copper GPU
    i5-3570k CPU
    ASrock extreme 4 motherboard
    8gb kingston hyper x 1600mhz
    360mm liquid cooling kit for gpu/cpu
    2x 128gb OCZ vertex 4 hard drives
    1,000 watt cooler master silent pro
    typica dvd driv
    Razer Lycosa keyboard/razer abysus mouse
    That seems pretty cheap for 1,770. can you build me something better for the same?
  5. Cyberpower builds it. The only reason I want them to build it is because I have never liquid cooled in my life. I want to liquid cool my CPU/GPU and it seems like it might be a daunting task. Other than that, I've built computers plenty of times.
    I'm willing to build it myself I suppose
Cyberpower Systems
