Hey all,
So i have an old ultra aluminus case from my old computer. Here is a link to the case.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1215768&CatId=1521
only difference is the color of mine.
I also have an ultra x connect 2 power supply that is 550 watts. Here is the link
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2974488&CatId=1079
Below are the parts I am considering putting in this case if anyone could advise if they should work temporarily till i am able to avoid a better power supply and case.
Processor:
I want to put in the case this processor or this one. Any other Recommendations appreciated
i-5 3540
http://www.microcenter.com/single_product_results.phtml?product_id=0388579
or this one
i-5 3570K
http://www.microcenter.com/single_product_results.phtml?product_id=0388577
Motherboard: Kind of partial to asus motherboards because of my past one, their warranty, and overall build quality. Other recommendations welcome
http://www.microcenter.com/single_product_results.phtml?product_id=0390655
or
http://www.microcenter.com/single_product_results.phtml?product_id=0366623
Ram:
Doesn't really matter much to me. Probably will only put in 8gb to start out.
Video Cards: Need Recommendations
Just need a simple low end one that will run guild wars 2 at a decent frame rate.
Overall looking for a motherboard that will allow for upgradeability in the future.
Thanks All!
Processor:
i-5 3540
or this one
i-5 3570K
or
Ram:
Thanks All!
