N120 Wireless Network Connection question
Last response: in Wireless Networking
My laptop connects to my wireless network (airport express) just fine, my son connects his laptops at my place without any trouble & simultaneously - my samsung n120 however gives me a 'limited or no internet access' message. When I try REPAIR It won't find the IP. I've set the IP option to auto & copied the DNS numbers from my Dell. I've updated the card driver - i've reset the IPCONFIG & I can still only get it to connect if my Dell isn't! Help please.
Hello and welcome to Tom's Hardware Forums.
That message can point to an incorrect wireless security key being used so check the key your son uses and make sure you input it carefully. It is sometimes case sensitive.
If I'm not running my Dell, the samsung connects without a problem.
key is correct settings are checked - as stated, SAMSUNG CONNECTS IF NO OTHER COMPUTERS ARE CONNECTED TO MY HOME NETWORK, but wont if there's another one connected?
Any suggestions?
Ask the community
