ok this is my problem...linksys cant figure it out nor can I....
the problem is with my wireless router. im trying to connect my desktop to the router wired, but its getting no connection, says "please connect Ethernet cable" but the ethernet cable is plugged it....anyway ive tried 3 different routers and they all do the same thing.
the only way i can get internet is if i plug my desktop straight into my modem via ethernet cable. but if i try to go though any of the 3 routers it dosent detect it at all...im not stupid either, i know how to setup my router, and ive tested all of the ethernet cables, they all work...also something weird, i am getting wifi from my router, and if i hookup my laptop to the same ethernet cable that was running into the back of my desktop, it works fine.
ive done everything, updated lan drivers, checked everything, i dont understand what could be he problem????
please help me out if u know how, or even if you have an idea, ill be willing to give it a try.
