Overheating problem
So i'am having problems with my pc temerature.I downloaded fanspeed and ran the program.My cpu tems are very low around 35 C ,but the core temp is high and it goes up to 110 C and then the computer shuts off and restarts.I cleaned my computer,making sure everything is dust free and theres nothing clogged up,but still the temperatures tend to rise.If Im chrking my email or doing anything not processor demanding it runs at about 60C butmif I start multitasking it will eventually go up pretty high.When it comes to gaming ,i simply can't play anything for more than 2 or 3 mins due to high temps and them getting blue screen of death.So yeah,I was wondering if anyone knows what i can do to fix this problem?I am desperate right now ,because I cant use my computer for anything even remotely demanding.
P.S? imhavent touched the settings of SpeedFan,because i dont know how to configure it.
6 answers Last reply
More about overheating problem
  1. what are the specs. What cpu - what cpu cooler - what case - what case cooler?
  2. My PC is HP Pavillion m7763w Media Center
    Everest Specs:
    Computer:
    Operating System Windows 7 Professional Professional
    OS Service Pack Service Pack 1
    DirectX 4.09.00.0904 (DirectX 9.0c)
    Computer Name
    User Name
    Motherboard:
    CPU Type Unknown, 2400 MHz
    Motherboard Name Unknown
    Motherboard Chipset Unknown
    System Memory 2048 MB
    BIOS Type Award (03/19/07)
    Display:
    Video Adapter NVIDIA GeForce 9400 GT
    Multimedia:
    Audio Adapter High Definition Audio Controller [NoDB]
    Storage:
    IDE Controller Standard Dual Channel PCI IDE Controller
    SCSI/RAID Controller NVIDIA nForce Serial ATA Controller
    Disk Drive SAMSUNG HD400LJ SCSI Disk Device (372 GB)
    Disk Drive Generic USB CF Reader USB Device
    Disk Drive Generic USB MS Reader USB Device
    Disk Drive Generic USB SD Reader USB Device
    Disk Drive Generic USB SM Reader USB Device
    Optical Drive DTSOFT Virtual CdRom Device
    Optical Drive TSSTcorp CD/DVDW TS-H653L SCSI CdRom Device
    SMART Hard Disks Status Unknown
    Partitions:
    C: (NTFS) 49898 MB (26173 MB free)
    D: (NTFS) 325141 MB (70368 MB free)
    E: (NTFS) 6408 MB (727 MB free)
    Total Size 372.5 GB (95.0 GB free)
    Input:
    Keyboard HID Keyboard Device
    Mouse HID-compliant mouse
    Network:
    Network Adapter HP 802.11b/g Wireless Network Adapter (192.168.1.3)
    Peripherals:
    Printer Fax
    Printer Microsoft XPS Document Writer
    USB1 Controller Standard OpenHCD USB Host Controller [NoDB]
    USB2 Controller Standard Enhanced PCI to USB Host Controller [NoDB]
    USB Device Lachesis Mouse
    USB Device Logitech Webcam 250
    USB Device USB Audio Device
    USB Device USB Composite Device
    USB Device USB Input Device
    USB Device USB Mass Storage Device
    DMI
    [ BIOS ]
    BIOS Properties:
    Vendor Phoenix Technologies, LTD
    Version 5.07
    Release Date 03/19/2007
    Size 512 KB
    Boot Devices Floppy Disk, Hard Disk, CD-ROM, ATAPI ZIP, LS-120
    Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS
    Supported Standards DMI, APM, ACPI, PnP
    Expansion Capabilities PCI, USB
    [ System ]
    System Properties:
    Manufacturer HP-Pavilion
    Product RT692AA-ABA m7763w
    Serial Number MXF7030B4Y
    Universal Unique ID 801D021E-D0141210-9FAF8926-0FDBBF91
    Wake-Up Type Power Switch
    [ Motherboard ]
    Motherboard Properties:
    Manufacturer ASUSTek Computer INC.
    Product NODUSM3
    Version 1.05
    Serial Number MB-1234567890
    [ Chassis ]
    Chassis Properties:
    Manufacturer Hewlett-Packard
    Version 1111
    Chassis Type Desktop Case
    Boot-Up State Safe
    Power Supply State Safe
    Thermal State Safe
    Security Status None
    [ Memory Controller ]
    Memory Controller Properties:
    Error Detection Method 64-bit ECC
    Error Correction None
    Supported Memory Interleave 1-Way
    Current Memory Interleave 1-Way
    Supported Memory Speeds 70ns, 60ns, 50ns
    Supported Memory Types SPM, SDRAM
    Supported Memory Voltages 2.9V
    Maximum Memory Module Size 1024 MB
    Memory Slots 4
    [ Processors / AMD Athlon(tm) 64 X2 Dual Core Processor 4600+ ]
    Processor Properties:
    Manufacturer AMD
    Version AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
    External Clock 200 MHz
    Maximum Clock 3700 MHz
    Current Clock 2400 MHz
    Type Central Processor
    Voltage 1.3 V
    Status Enabled
    Socket Designation Socket AM2
    [ Caches / L1 Cache ]
    Cache Properties:
    Type Internal
    Status Enabled
    Operational Mode Write-Back
    Associativity 4-way Set-Associative
    Maximum Size 128 KB
    Installed Size 128 KB
    Supported SRAM Type Synchronous
    Current SRAM Type Synchronous
    Error Correction Single-bit ECC
    Socket Designation L1 Cache
    [ Caches / L2 Cache ]
    Cache Properties:
    Type Internal
    Status Enabled
    Maximum Size 512 KB
    Installed Size 512 KB
    Socket Designation L2 Cache
    [ Memory Modules / A0 ]
    Memory Module Properties:
    Socket Designation A0
    Type DIMM
    Speed 70 ns
    Installed Size 1024 MB
    Enabled Size 1024 MB
    [ Memory Modules / A1 ]
    Socket Designation A1
    Type DIMM
    Speed 70 ns
    [ Memory Modules / A2 ]
    Socket Designation A2
    Installed Size Not Installed
    Enabled Size Not Installed
    [ Memory Modules / A3 ]
    Socket Designation A3
    [ Memory Devices / A0 ]
    Memory Device Properties:
    Form Factor DIMM
    Size 1024 MB
    Speed 533 MHz
    Total Width 64-bit
    Data Width 64-bit
    Device Locator A0
    Bank Locator Bank0/1
    Manufacturer None
    Serial Number None
    Asset Tag None
    Part Number None
    [ Memory Devices / A1 ]
    Form Factor DIMM
    Size 1024 MB
    Speed 533 MHz
    Total Width 64-bit
    Data Width 64-bit
    Device Locator A1
    Bank Locator Bank2/3
    Manufacturer None
    Serial Number None
    Asset Tag None
    Part Number None
    [ Memory Devices / A2 ]
    Form Factor DIMM
    Total Width 64-bit
    Data Width 64-bit
    Device Locator A2
    Bank Locator Bank4/5
    Manufacturer None
    Serial Number None
    Asset Tag None
    Part Number None
    [ Memory Devices / A3 ]
    Form Factor DIMM
    Total Width 64-bit
    Data Width 64-bit
    Device Locator A3
    Bank Locator Bank6/7
    Manufacturer None
    Serial Number None
    Asset Tag None
    Part Number None
    [ System Slots / PCI1 ]
    System Slot Properties:
    Slot Designation PCI1
    Type PCI
    Usage Empty
    Data Bus Width 32-bit
    Length Short
    [ System Slots / PCI2 ]
    Slot Designation PCI2
    Type PCI
    Usage In Use
    Length Short
    [ System Slots / PCI3 ]
    Slot Designation PCI3
    Type PCI
    Usage In Use
    Length Short
    [ System Slots / PCIEX16 ]
    Slot Designation PCIEX16
    Type PCI-E x1
    Usage In Use
    Length Short
    Overclock
    CPU Properties:
    CPU Type Unknown
    CPUID CPU Name AMD Athlon(tm) 64 X2 Dual Core Processor 4600+
    CPUID Revision 00040FB2h
    CPU Speed:
    CPU Clock 2405.01 MHz
    CPU Cache:
    L1 Code Cache 64 KB
    L1 Data Cache 64 KB
    L2 Cache 512 KB (Asynchronous)
    Motherboard ID 03/19/2007-C51/MCP51-A8M2N-LA-00
    BIOS Properties:
    System BIOS Date 03/19/07
    Video BIOS Date 08/14/08
    Award BIOS Type Phoenix - AwardBIOS v6.00PG
    Award BIOS Message Copyright 2007 by Hewlett-Packard Company Rev. 5.07
    DMI BIOS Version 5.07
    Power Management
    Power Management Properties:
    Current Power Source AC Line
    Battery Status No Battery
    Full Battery Lifetime Unknown
    Remaining Battery Lifetime Unknown
    Sensor
    Temperatures:
    CPU 40 °C (104 °F)
    CPU
    CPU Properties:
    Instruction Set x86, x86-64, MMX, 3DNow!, SSE, SSE2, SSE3
    L1 Code Cache 64 KB
    L1 Data Cache 64 KB
    Multi CPU:
    Motherboard ID OEM00000 PROD00000000
    CPU #0 AMD Athlon(tm) 64 X2 Dual Core Processor 4600+, 2405 MHz
    CPU #1 AMD Athlon(tm) 64 X2 Dual Core Processor 4600+, 2405 MHz
    CPU Utilization:
    CPU #1 / Core #1 0 %
    CPU #1 / Core #2 100 %
    Hope this helps. Have added a new GPU,now with two one disabled,becasue PC is not custom and cant remove the old GPU.New one is EVGA nVIDIA GeForce 9400 GT 1GB
    Actually found more useful info on their website :
    Specs:
    Introduction date
    10-Jan-2007
    Country/region sold in:
    US
    Canada
    Hardware
    Base processor
    Athlon 64 X2 (W) 4600+ 2.4 GHz
    2000 MT/s (mega transfers/second)
    Socket AM2
    Chipset
    GeForce 6150 LE. <----- Old GPU.
    Motherboard
    Manufacturer: Asus
    Motherboard Name: A8M2N-LA
    HP/Compaq motherboard name: NodusM3-GL8E
    Memory
    Component Attributes
    Memory Installed 2 GB
    Maximum allowed 4 GB* (4 x 1 GB)
    *Actual available memory may be less
    Speed supported PC2-4200 MB/sec
    Type 240 pin, DDR2 SDRAM
    Hard drive
    400 GB SATA
    7200 rpm
    16X DVD(+/-)R/RW 12X RAM (+/-)R DL LightScribe SATA drive
    Must use Double-Layer media discs in order to take advantage of the DL technology
    Must use LightScribe-enabled media discs and supporting software in order to take advantage of the LightScribe technology
    Function Maximum speed
    DVD-RAM Up to 12X
    DVD-R DL Write Once Up to 8X
    DVD+R DL Write Once Up to 8X
    DVD+R Write Once Up to 16X
    DVD+RW Rewritable Up to 8X
    DVD-R Write Once Up to 16X
    DVD-RW Rewritable Up to 6X
    DVD ROM Read Up to 16X
    CD-R Write Once Up to 40X
    CD-RW Rewritable Up to 32X
    CD-ROM Read Up to 40X
    Modem
    56K bps data/fax modem
    Wireless
    Wireless LAN 802.11 b/g
    Video Graphics
    Integrated graphics
    Television
    TV tuner card with FM tuner
    Sound/Audio
    Integrated High Definition audio
    Realtek ALC 888 chipset
    Supports up to 8 audio channels
    Dolby Pro Logic II compatible
    Network (LAN)
    Integrated 10/100 Base-T networking interface
    Memory card reader
  3. Hi,Ive uploaded a few picutres to show you exactly what happens with my PC.
    Hope this helps.
    I can't upload them as separate images to the forum,because they won't show so I'm going to give a link to my photobucket library
    http://s1094.beta.photobucket.com/user/Hristos_Gyurov/library/
    Also in addition to this,when I place my hand behind the power supply fan,the air coming out is warm.
  4. I cant seem to configure SpeedFan too,I found a guide but,when I go to the advanced tab,I cant change the speed control from on AMBIENT to manually control.
    Please help,anyone!?!
    I really want to fix my problem,I thought people here would know what my problem is and tell me what to do by now,I have more than 70 views on my thread by now,and only one reply and I've already provided enough information I think,even pictures of my system.
    If there's more info you need I'd be glad to provide it.Its just that I need an answer if I need to replace a part that is faulty.I don't really wanna cough up money for someone else to fix it,when I can probably do it myself,if I knew what was wrong with it.
  5. Check the fans inside the case.
    let us know what you have for fans in there as I cont find much info on it. Ideally you'll have 1 in the side, 1 in the lower front, one on the cpu cooler, and one in the upper rear.
    Also, the pc's location makes a difference too, The hot air blowing out needs a way out and cool air needs a way in so putting the case in a cabinet is not a good idea you see.
  6. Only these 2 fans and the fan on the power supply.That's it.
CPUs Computers
