Will it work 1 videocard at x16 the other card x4 for physics?
  • Graphics Cards
  • Bandwidth
  • Motherboards
  • Graphics
June 10, 2012 11:52:09 AM
I want to use 1 video card at the full x16 bandwidth and add another card in the x4 slot for physics on a motherboard that has 1 x16 @ 1 x4. What value do I gain?
More about : work videocard x16 card physics
June 10, 2012 12:32:18 PM
I t would be nvidia, something like a 2gb card for x16 slot and something small just for physics for the x4 slot. Will it work with no limitations?
m
l
June 10, 2012 12:38:59 PM
yeah something like that!
m
l
June 10, 2012 12:46:45 PM
It look's like the only way SLI and X-fire works if you spend a ton of money. I thought that maybe I could cut cost by just getting one big card for rendering and a smaller card for physic's to take the load off wihtout losing any bandwidth from the x16 slot.
m
l
