Help me pick my parts?
Last response: in Systems
August 1, 2012 7:46:29 AM
Hi, I'm planning on building a computer. My budget is $700 and I am planning to play games like Bf3, Minecraft, League of Legends, and other games that will be purchased on Steam. But I dont know what parts to buy, so I came here. Can you recommend some parts to help me start? Thanks! :D
Also it is my first time ever building a computer.
More about : pick parts
August 1, 2012 8:09:40 AM
Its possible, but don't expect great performance. If you need an OS and monitor, they will cut into the builds budget by a lot.
CPU: AMD Phenom II x4 . $110
Pretty much the only budget "true" quad core worth getting.
Mobo: AsRock 970 Extreme3 AM3+. $70
This board will let you upgrade to Bulldozer or Piledriver if you wanted later.
RAM: G.Skill Ripjaws series 8GB (2x4GB) 1600Mhz CL9 1.5v. $46
HDD: Seagate Barracuda 1TB 7200RPM. $90
Or to save a bit of cash
Western Digital Caviar Blue 500GB. $75
PSU: Seasonic 520W, 80+ Bronze, modular. $60
Be careful with this supply, it has two 12v rails and make sure not to put the burden all on one.
GPU: Gigabyte HD7850. $260
Case: Zalman Z9+. $53
Very good budget case, surprised they can get a profit off this thing.
Total: $689 (with the 1TB HDD)
This rig will be good for medium level gaming.
m
l
August 1, 2012 8:45:54 AM
Well here's an Intel rig that I whipped up that I think would do OP just fine. It's cutting it close for his budget, though.
Intel Core i5 3450 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
ASRock H77M Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
G. Skill Ripjaws X 1600Mhz CL9 RAM - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Corsair CX500w PSU - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
XFX Core Radeon HD7850 - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Samsung Spinpoint 500GB HDD - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Cooler Master Elite 430 Case - http://www.newegg.com/Product/Product.aspx?Item=N82E168...
Total price after shipping and discounts - $713.26 that's BEFORE rebates. Now let's add in the rebates.
$20 rebate on the GPU and $20 rebate on the PSU, which is a total of $40 of rebates. $713.26 minus the $40 rebate gives you a grand total of $673.26
m
l
August 1, 2012 11:35:07 AM
Imo, OP would be better with an i5. But, thats just me. :D
m
l
