New build, but restart after 3 second I press the power button! HELP!!
Last response: in Components
- PC restarts after 5 seconds from pressing the power on button - Tech Support
- i have acer notebook d270. while i am press the power button only light blink for 10 second and after that nothing displyed an - Tech Support
- first time build. a one second spin of the fans and then nothing after pressing the power button - Forum
- Help! When i press the power button the computer only starts for a split second then turns off. - Tech Support
- Solved5 second delay after pressing power button and start-up solution
- asus laptop K53S. got lights for a second when pressing power button then they turn off..need help.. solution
- first time building computer, nothing happens after pressing power button solution
- SolvedWhile new pc with GA-H87-HD3 H87 + i5-4690 = won't boot, start, no post, no sound errors, restart every second, help me please solution
- SolvedCPU on , but Monitor starts only after repeatedly pressing RESTART button. solution
- First PC build motherboard lights are on. Press power button but nothing. Press the motherboard power button... Forum
- SolvedPC Turns off after a split second of hitting power button solution
- I`m stuck at the press esc for start up menu button after setting up a new GPU? solution
- SolvedPC loses power right after pressing power button. solution
- SolvedPower button won't restart computer after sleep/hibernation solution
- SolvedComputer has a delay on powering up after pressing power button solution
- SolvedNew i3 2100 build can't be Shut Down! Restarts after 5 seconds. Forum
- whenever i press on button on my wireless optical mouse, the bottom part does blink, but after a few seconds, it's not blinkin solution
- hellow i got the same problem and i remove the battery and press the power button for 60 seconds and plug in the battery but s solution
- SolvedNew pc build power button turns on but not off,please help solution
- More resources
Read discussions in other Components categories
