Sign-in / Sign-up
Advice on Final Build/PSU help
  • Build
  • Hard Drives
  • Systems
  • Product
Last response: in Systems
August 1, 2012 4:18:36 PM
Hey guys, after days of research this is what I have scrapped up.
Cpu: http://www.newegg.com/Product/Product.aspx?Item=N82E168... $110
Mobo: http://www.amazon.com/ASUS-Sabertooth-990FX-Series-Moth... $165
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E168... $215
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E168... $46
HDD: http://us.ncix.com/products/?sku=58402&vpn=WD5000AAKX&m... $61
Case: http://www.amazon.com/RAIDMAX-SMILODON-Extreme-Tower-AT... $75
I am looking to keep this build under $730. I need help on finding a psu to supplement the rest of my build.
The problem is that NewEgg charges sales tax in New Jersey so it's a pain to find good deals on other sites.
Thanks,
Gavner
More about : advice final build psu
August 1, 2012 4:23:50 PM
you can get the i5 3450 for 149.99 at microcenter if you live near one
m
l
August 1, 2012 4:24:29 PM
TheBigTroll said:
scorpio drives are for laptops.they are slowwwwww
get this instead. it costs more but performs much better
http://pcpartpicker.com/p/dAeL
I have to keep it sub $65 for the HDD 320gb should be enough for gaming shouldn't it?
m
l
August 1, 2012 4:28:15 PM
my hard drive is cheaper than yours...
m
l
August 1, 2012 4:29:58 PM
Oh, i compared it with the Newegg price. Thanks, noted.
m
l
August 1, 2012 5:05:42 PM
Anyone else?
m
l
