Is my power supply sufficient for this card?
  • Graphics Cards
  • Dell Studio Xps
  • Power Supplies
  • Graphics
June 11, 2012 1:54:35 AM
Hi, I am thinking about getting an AMD Radeon HD 6950.
http://www.amd.com/us/products/desktop/graphics/amd-rad...
I currently have a Dell Studio XPS 9100, and I've been told that the power supply is 525w, and the card draws 500w.
Will I be ok power-wise running this card in my machine?
I use it primarily for gaming, stuff like Blacklight: Retribution, TF2, Minecraft (trying to add in some really heavy-duty shaders)
Also, I do a little 3D animation with Maya and Blender.
Thanks in advance.
More about : power supply sufficient card
June 11, 2012 2:39:55 AM
Maybe you will not face too much problem.but 2 years ago i had problems similar to you and it worked without problems for 6 months.then one day it suddenly blew ...i think it'll be safe if you change your psu .
m
l
a c 342 U Graphics card
a c 166 ) Power supply
June 11, 2012 3:11:50 AM
First off use this calculator to fiqure the size PSU you need. The other parts of your system also require wattage from the PSU.
http://www.thermaltake.outervision.com/
The HD 6950 only uses 176W at its max. So 176W/+12V=14.7amps. Be sure your +12V rail(s) can handle at least that many amps (your CPU and other components also use the +12V rail). http://forums.atomicmpc.com.au/index.php?showtopic=264
Tom's ranks the HD 6950 and the GTX 560ti in the same tier. http://www.tomshardware.com/reviews/gaming-graphics-car...
But here is a calculator to judge the cards 'on paper' anyway... http://www.hwcompare.com/8889/geforce-gtx-560-ti-vs-rad...
m
l
