New PC build, not getting any monitor signal
Hi, I built a new pc:
The specs are
32GB Ram
i7 3770k lga 1155
Asus b75 motherboard
1.5 TB HDD w/ 60 gb ssd
HAF 912 case
Dvd/blue ray burner
750W 80+ bronze certified PSU corsair
I put everything together and I am not getting a monitor signal
Please keep in mind: My GPU accepts DVI, HDMI and 2 hdmi mini ports.
My motherboard has a DVI and VGA port.
My monitor accepts VGA and DVI no hdmi :/
I had no DVI cables so I was forced to use VGA. So i'm using VGA from my motherboard and NOT my GPU.
I still get no signal.
All of the fans turn on, CD drive opens, HDD leds, power switch works, and I even get a post bleep.
What am I doing wrong, could it be that my CPU does not want to be configured with my GPU..
Or maybe I just need to get a DVI cable and plug it into my GPU?
Thanks for reading. I hope I can get this resolved asap.
3 answers Last reply
More about build monitor signal
  1. Perform all the steps in our standard troubleshooting guide and let us know how it goes. There's a link to the troubleshooting checklist in my signature.
  2. Bought a DVI and it solved my problem.
    Thanks.
  3. i see a problem with your build: you wasted the overclocking ability of the 3770k since b75 doesnt support it
    if you werent overclocking it, get a 3770
    if you are, get a z77 motherboard instead
New Build DVI Monitors Systems
