Problem with CPU Cooling.
Hello,
I recently purchased an AMD FX-4170 (Despite criticism i personally think its a good gaming CPU), and the Xigmatek Prime cooling Heatsink and fan. I wanted to test out my new CPU by playing Planetside 2 on full specs, after 5 minutes of gameplay my system automatically without warning, switches itself off... Immediately i am baffled. I later found out that my CPU was rising to temperatures beyond 100 degrees Celcius.
Now if the heatsink was not connected properly then the CPU would have fried (i'm guessing). and the Cooling fans are operational. So i don't know what the problem is ?
All help is appreciated. Thanks!
AMD FX-4170
AMD HD Radeon 7870
8GB Transcend RAM
Gigabyte GA-970A-DS3
Zalman Z11 Case
5 answers Last reply
More about problem cooling
  1. DL4ADX said:
    Hello,
    AMD FX-4170
    AMD HD Radeon 7870
    8GB Transcend RAM
    Zalman Z11 Case
    Did you use the coolers thermal compound? or did you buy your own?
    The computer was assembled by a gaming website, but if i had to guess, they would use the Compound that came with the cooler.
  3. I believe the CPU did not fry but instead its shut off due to the overheating shut down which is used to prevent the processor from damage. Since you bought this pre-built you should contact whomever you bought the computer from, if you alter the computer yourself, you may void warranty....
    Thank you for the reply.
  5. You are welcome :)
    Make sure to contact the manufacturer of your build and they should fix it. Most likely they did not install the cooler right or no thermal paste...or it could even be a dead fan. If you find the problem out they will send you a replacement part for you to swap out yourself.
Cooling CPUs AMD Components
