I have been planning on getting a new headset (Razer Tiamat 2.2) http://www.newegg.com/Product/Product.aspx?Item=N82E16826153088
Since I'm planning on upgrading my headset, I have started considering adding a sound card to my build. I am not looking to spend more money than needed. I want a card that will give me boosted sound quality to go along with the new headset without going way overboard. I have been considering the Creative Sound Blaster Recon3D SB1350 http://www.amazon.com/exec/obidos/ASIN/B00654PUPA/cupcre06-20
Is this a good choice or is there a card that you think gives a better bang for the buck
My specs:
Gigabyte GA-Z77-UD3H
Intel i5 3570k
Sapphire Radeon 6950 2GB
8GB RAM
750W Power Supply
My specs:
Intel i5 3570k
8GB RAM
750W Power Supply
