Hello Folks,
I need some help with CPU temps. I have an Intel i7 950 3.0 Ghz. I actually have a question, and some information that I found out that is a side-related thing.
I have seen a million different opinions about what safe temps are for CPU'S. Intel gives their own recommended temp ranges of course.
My i7 is in a huge gaming tower, about 2 years old, superior ventilation, five case fans + RAM cooling. It has typically idled at about 39-42c, and goes up to about the high 50s to low to mid 60s when under load, gaming, etc. My i7 has stock Intel cooling, nothing special added.
Occasionaly it will go into the high 60s to the very, very low 70s like when Norton is udpating, etc. In two years, my CPU has NEVER gotten above 72 or 73c, and only for very, very short periods when it hit those temps.
My question is, is an idle temp of 39-42c, and load temp of 55-65c, and only occasionaly approaching 70c ok? I have read that even though Intel recommends that the i7 950 should never go above 67c, that it is designed to run hot, and can go into the 70s and even 80s, and still be fine, and wont shut itself down until it reaches 100c. I have also read that yes, you can run i7's hot, but that you will shorten their life.
Figured I'd ask you folks, as you have a lot more knowledge on this than me!
Thanks in advance.
Thanks in advance.
