Water pump
Hi,
Iam trying to install a CPU water pump, i got it from a friend... i think it is a H60 but im not sure.
The power cable from the pump to the mother, have an connector i dont have on my motherboard :S
I was wondering any of you awesome people know what this cable is called or if i can make a converter or solder it to another power cable.
1 answer Last reply
More about water pump
  1. well that's odd corsair normally has two wires for pump and fan so someone has modified it because its supposed to have 2 3 pin wires
Cable Power Motherboards Components
