G
Guest
Guest
My new build (1 month) occasionally, when switching on, powers up the fans then cuts out before the MOBO attempts to boot. So i doubt it is a MOBO problem. Has any one had this issue before. When i turn it off at the back and turn on again it usually powers up fine, i think it could be a psu problem. this often occurs after i flip my PSU switch on. (i usually turn this off when im finished with my pc). Also im in UK just FYI
Specs: -CiT Mars Midi Tower Gaming Case with 2 x Blue LED Fans & LED Display -Corsair CMZ8GX3M2A1600C9 8GB 1600MHz CL9 DDR3 Vengeance -Memory Two Module Kit -ASUS AM3+ SABERTOOTH 990FX S/L -Seagate ST2000DL003 Barracuda Green 3.5-inch 2TB SATA 6 Gb/s -Drive (64MB Buffer,5900RPM) (secondary HDD) -Sapphire HD6670 2GB DDR3 Graphics Card -Powercool 850W Black 80+ Standard ATX Computer PSU Power Supply Unit with 12cm Fan (White Boxed) -SanDisk 120GB Extreme Solid State Drive (2.5in SATA III 6Gb/s) -AMD FX-8150 Eight Core Processor - 3.60GHz, 16MB, L3 Cache, Socket AM3+
I am also novice at this so please explain with clarity and detail. thanks
