Solved
Help with New Build
Approximate Purchase Date:this month (the closer the better)
Budget Range: (e.g.: 700-800) Before Rebates; After Shipping
System Usage from Most to Least Important: programming, 3d modeling with maya and zbrush, gaming, surfing the internet, watching movies(just DVDs), I also have usually 15-20 tabs open in firefox.
Are you buying a monitor:later(price not included)
Parts to Upgrade: (e.g.: CPU, mobo, RAM, case, power supply (everything that goes in the case.
Do you need to buy OS:No
Preferred Website(s) for Parts: e.g.: newegg.com, ncix.com, tigerdirect.com any others with good ratings?
Parts Preferences: none performance and reliability is all that matters
Overclocking: Maybe a little
SLI or Crossfire: Maybe (doesn't have to be now)
Your Monitor Resolution: idk yet
Additional Comments: would like the case to have a window, and look nice. Programs I use are zBrush, Maya, Code::Blocks, Diablo 3, and other everyday programs. I would like to have at least 8gb of ram and a dedicated gpu.
And Most Importantly, Why Are You Upgrading: Using an AMD 64 3500+ right now and its just not cutting it; it can't handle games or my modeling.
Include a list of any parts you have already selected with descriptively labeled links for parts. Please do not post only links.
I have been looking at parts like the i5 3570k, coolermaster storm scout case, and the asrock extreme4 mobo.
8 answers Last reply Best Answer
More about help build
  1. For the Case, I would recommend the 50$ Cooler Master 430 or the 100$ Antec Nine Hundred, both of which have windows. Maybe go AMD for the CPU with one of their 6 or 8 core models that are about $180. Make sure your mobo has plenty of expansion slots, at least 7, if not 10.
  2. I'd rather get the Eleven Hundred for its cable management.
  3. Best answer
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1030096 $306.98 save: $18.00
    Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
    ASRock Z77 Pro3 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 $34.99 - $29.99 after mail-in rebate FREE SHIPPING
    COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231545 $88.99 FREE SHIPPING
    G.SKILL Ares Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9Q-16GAO
    http://www.amazon.com/Sony-AD-7280S-0B-Internal-Drive-Black/dp/B0057FRTPW/ref=pd_cp_e_1 $16.99 & eligible for FREE Super Saver Shipping on orders over $25
    Sony AD-7280S-0B 24x SATA Internal DVD+/-RW Drive (Black)
    http://www.amazon.com/Seagate-Barracuda-3-5-Inch-Internal-ST1000DM003/dp/B005T3GRNW/ref=sr_1_4?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1343861864&sr=1-4 $80.68 & this item ships for FREE with Super Saver Shipping
    Seagate Barracuda 7200 1 TB 7200RPM SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST1000DM003
    or...
    http://www.amazon.com/Seagate-Barracuda-7200RPM-Internal-STBD2000101/dp/B005OKQUJ6/ref=sr_1_18?m=ATVPDKIKX0DER&s=pc&ie=UTF8&qid=1343928414&sr=1-18 $109.99 & this item ships for FREE with Super Saver Shipping
    Seagate Barracuda 7200 2 TB 7200RPM SATA NCQ 64MB Cache 3.5 Inch Internal Desktop Hard Drive STBD2000101 - Retail Kit
  4. It's great to have Why_Me replying to threads again. :)
    The HAF 912 or Corsair 400R would be far better choices for the prices recommended. I'd also second the Antec 1100 but it's definitely much bigger than the latter cases.
    I would not go AMD FX when any Intel Sandy Bridge / Ivy Bridge build completely destroys them.
  6. Not to mention, AMD Phenoms destroy them too.
    or...
    Thanks for the excellent reply and I have decided to use this build except I will go with 8gb of ram and the Coolermaster storm scout case. Thankyou :)
  8. Best answer selected by c++H4x3r.
New Build Systems Product
