Archived from groups: alt.cellular.nokia (More info?)
I have a Nokia 6600 mobile phone & wondered if you can help me with a
problem. I have a Bluetooth headset so I can use the phone hands free.
So that I can ring numbers I without touching the phone I am creating
voice-tags. For a lot of my contacts I have entered a mobile number and a
home number.
My problem is that I can only create 1 voice-tag per contact. & I have to
decide if I want to create a voice-tag for their home number or their mobile
number.
Does anyone know if there is a way I can create a voice-tag for home &
mobile numbers for the same contact?
"Neil Hindry" <n_nospam_hindry@_nospam_hotmail.com> wrote in message
news:4119fc65$0$193$db0fefd9@news.zen.co.uk...
> home number.
mobile
> number.
> Is there any way around this at all?
> I hope you can help,
> I appreciate any help or information given.
> Thanks
Don't wish to sound patronising, but are you SURE you can only create one VT
per contact? It seems really odd that if the phone lets you create a contact
with 2(or more) numbers you can only create one VT per contact.
On my phone, (also a Nokia, though not a 6600). If you open a contact then
you can scroll through the various numbers under that contact, and under
options(for each number) is an 'Add Voice Tag'. So you can add one for any
or all numbers under that contact.
I suggest you study the manual carefully, but if it is really true and it is
restricted to 1 per contact, then I can only say Boo! to Nokia for being
rubbish, and echo Mr Pollard's advice to create a separate contact for each
number you want to create a VT for. (How c*** is that!)
Cheers,
ChrisM.
Please remove shoes to reply
But what ... is it good for?
- Engineer at the Advanced Computing Systems Division of IBM, 1968,
commenting on the microchip.
> Well, I suspect the only way would be to save their home and mobile
numbers
> under seperate entries, like they were different contacts.
> Chris Pollard
Confirming this is the solution.
