Since the CM Hyper 212 evo is a popular and great-performing CPU cooler for the price, I want to use it inside my NZXT gamma classic series case. The height of the 212 evo is 160mm, and the width of the case is 7.4 in. (185mm). However, the internal case width may be narrower. I don't want the side panel not being able to go on, because I need the side panel to be on. It does not have any fans, or fan holes. Also, I don't want the 212 evo being such a tight fit that it pushes down on the CPU a lot. I looked all over the internet and couldn't find the internal width of the case (from the motherboard mounting stuff to the side panel).
So will the CM hyper 212 evo be able to fit without compressing the CPU excessively? Or is pressure on the CPU good? If this cooler doesn't fit, then what is the maximum height of one that will fit?
