Hello,
I'm new to the forums. I'm pretty good with PC's and rebuilt one from scratch however recently my PC has been giving me the weirdest trouble.
First off it seems the CPU will lose power yet the graphics card fan still spins and the lights on the motherboard are still on. The CPU will just stop and the PC does a hard shutdown, entirely turning off save the graphics card and motherboard. This is random.
I have a hunch it may be my power source as theres a small clicking in it which I'm assuming is the fan in it going out. Is it possible the power source could be overheating?
I've been using HW monitor to monitor the temps and the CPU temperature staying around 7-14 celsius. Occasionally it MIGHT spike up to 30 playing some games and stressing it but other than that it stays cool.
The motherboard hovers at around 37-42 mostly
And the graphics card anywhere between 30-50 depending on games, graphics resolution etc.
Windows 7 64 bit professional
8 gigs of Ram Corsair
AMD Fx 4100 quad core 3.6 ghz
Nvidia GTS 250
I also want to mention that I might possibly have a short in the power supply as sometimes the machine won't power back on unless I wiggle one of the large power cords. I've checked and made sure it's seated on the motherboard correctly and I'm 100% certain it is. The power source is about 4-5 years old now..
Those are the specs of my machine. If you need anything extra I'll add it in there. Thanks for the input guys.
Nvidia GTS 250
