G
Guest
Guest
This is a really basic question for this forum, but it would be great if someone could help out.
I have two internal hd's and would like to add a Maxtor 80g FW drive. This drive is currently formated for a mac.
I've just installed a maxtor FW pci card, and WinMe found the drivers for it.
If I start up the FW drive, and then boot up, would WinMe detect new hardware then prompt to format/partition etc., or do I need to run msdos and fdisk. If I need to fdisk, would someone please advise me the steps required to format the FW for my setup? I only need one partition.
Current devices in use:
Int hd master C
Int hd slave D
cdrw E
cdrom F
Should I be concerned about drive letter changes to the cd drives when installing the fw drive?
Thank you.
Int hd master C
Int hd slave D
cdrw E
cdrom F
Thank you.
