New build system kinda slow
Last response: in Systems
August 3, 2012 8:47:15 AM
Just built my computer, ASUS Sabertooth z77, i7 3770K with 8 G memory. I'm running Windows 7 64 bit. But the system would take almost 2 mins to get ready after certain drivers installed. I tried to install the system twice. The problem kept coming up. Is it because of the bad drivers I installed or too much useless drivers? I didn't install the latest BIOS drivers since the default version works fine.
So could anyone please enlighten me on this? :)  And also how much time, on average, would a brand new build computer take to get ready for you guys?
Thank you very much.
August 3, 2012 8:53:55 AM
Maybe you installed old drivers lol. Check if you have the latest ones, always.
m
l
August 3, 2012 9:43:43 AM
Ok, I will try to install all the new drivers tmr and see how it goes. Thanks!
m
l
August 3, 2012 11:32:54 AM
are you using a hard drive? SSDs can really fix that
m
l
August 3, 2012 7:28:43 PM
Yeah, I'm currently using a hard drive. But still, I think the speed is slower thank my friends' computer. They are also using hard drives.
m
l
August 3, 2012 7:31:23 PM
try the BIOS update it might help
m
l
August 3, 2012 7:47:48 PM
I think I will cause I never got the latest BIOS driver from the website.
m
l
August 3, 2012 7:59:46 PM
let me know if it works
m
l
August 3, 2012 10:42:26 PM
Sure!
m
l
