Will this CPU cooler's bracket work for my one now
Well I really want to get this cooler so I have something that will cool my CPU very well so I can overclock it. I found this cooler http://www.newegg.com/Product/Product.aspx?Item=N82E16835181016
and it fit all my questions. But one
With the bracket that I installed to the back of my motherboard for my Hypo plus (cooler master) fit, or will I have to completely remove the entire motherboard. ( which I do not want to do)
Any help with be appreciated!!!!
My socket size is 1155, intel core i7 2600k stock clock.
If you need any more information, let me know.
Thanks everybody.
1 answer Last reply
More about will cooler bracket work
  1. It might but then again it is different manufacturer so all the hardware might not be compatible.
CPUs Cooling Motherboards Product
