Closed Solved
Does the Cooler Master HAF X support the CORSAIR H100i Water Cooler
I am told that the duel radiators are not compatible on the top. Also that I should switch to the CORSAIR Hydro Series H80i Water Cooler. I know that the H80 will fit but I plan to do some overclocking. Duel radiators seem to cool faster and more efficiently.
Corsair Water Cooler H80i:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181031
Corsair Water Cooler H100i:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181032
Cooler Master HAF X:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119225
15 answers Last reply Best Answer
More about does cooler master support corsair h100i water cooler
  1. Thanks again! I am taking that you are saying yes. Is this your build? Was it hard to mount?
  2. Best answer
    Oh no, its not my build at all! I'm running on a mere Kuhler 620 (like the H60)
    Regardless take a look at this and scroll to the compatible cases for the H100, it says no modding required
    http://www.overclock.net/t/1144409/h80-h100-case-compatibility-thread-page-1-for-full-listings
    Thanks for the link. You are doing a lot more me :). Its says no moding but what is person trying to say in the second sentence? "Some modding may be required for P/P, may fit some cases without modding, HW dependant. "
  4. *You are doing a lot for me :)
  5. I believe P/P means push pull, that means you will have a total of four fans on the radiator...as seen in the picture four fans are used without any issues. If you are planning on replacing the stock fans and placing four specialized radiator fans let me know, I think I know the exact model of those fans.
    Alright thanks for the info!
  7. Best answer selected by FlyingSentry.
  8. You are most welcome :)
  9. socialfox said:
    Do you have a H100i?
    Nope, I stated in another post that that build was not mine. In fact, I own the Kuhler 620 H2O which is a different closed loop water cooler that mounts on a 120mm slot not 240mm. Why are you considering on getting it?
    I'm considering this.
    Not bad at all! Nice to see your going after custom water cooling kits rather than your average closed loop water cooler.
    Now back to choosing thermal paste...
    This should help you out pick a thermal paste....
    http://www.tomshardware.com/forum/274824-29-thermal-compound-roundup-2011
Cooler Master Cooling Corsair Components Product
