Solved
HELP WITH CHOOSING GRAPHICS CARD
I'm going to buy a video card to put into my back up computer until I can get my RMA back let me know which ones the best out of the ones I've chosen.
MSI R6670-MD1GD5 Radeon HD 6670 1GB 128-bit GDDR5
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127586
ASUS ENGT440/DI/1GD5 GeForce GT 440 (Fermi) 1GB 128-bit GDDR5
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121426
XFX HD-675X-ZDFC Radeon HD 6750 1GB 128-bit GDDR5
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150602
5 answers Last reply Best Answer
More about help choosing graphics card
  1. I'd just get a used 6450 or something super cheap on eBay if I were you, but if you really want to burn cash, the 6750 is the best of those cards.
  2. I think im choosing between the 440 and 6750. Can they both play ARMA 2.
  3. Best answer
    The 6750 is better, if you also have a decent cpu you will be able to play ARMA 2.
    And this with BF3 with low graphic settings at 1920x1080. Your framerates will be slightly higher if you play lower resolutions.
  4. Ok then it should be fine my monitor is only 1440x900 and the processor is a AMD Phenom II x4 BE. Thanks for your input really helped out.
    http://media.bestofmicro.com/6/T/339797/original/BF3%201920.png
  5. Best answer selected by abcasperr.
Graphics Cards HD Radeon Graphics Product
