Solved
Basic system under $300? Is it worth building?
Hi all,
My brother needs a computer to do the following: everyday email, web surfing, watching dvds, youtube videos, netflix, etc. and regular office work using MS Word, Excel, etc.
Is it possible to build a new and fast computer for what he needs under $300? I do have Win XP Pro and MS Office 2003 Pro.
Also, it is worth the effort or should I pay $379 and buy him a Dell Inspiron?
Forgot to add: if it is worth building it and can be done for about $300, what parts should I get? Case, CPU, Mobo, Power, HDD? anything else?
3 answers Last reply Best Answer
More about basic system worth building
  1. Well, the monitor, and HDD themselves will cost $200 alone. It's impossible unless you buy used parts. However, for $379, you could build a computer just as good as an Inspiron.
  2. Best answer
    Windows XP is EXTREMELY old... You should upgrade to Windows 8 for a small price later in the year if you build this.
    Intel Pentium G630 Sandy Bridge 2.7GHz - 68
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819116406
    ZALMAN Z9 Black Steel / Plastic ATX Mid Tower Computer Case - $45
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811235026
    ASUS P8H61-M LX PLUS LGA 1155 Intel H61 Micro ATX motherboard - $48 (HUGE SALE)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813131793R
    CORSAIR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 Desktop Memory - 25
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820145278
    SeaSonic SS-300ET Bronze 300W ATX12V V2.3 80 PLUS BRONZE Certified Active PFC Power Supply - 40 (Good sale)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151086
    Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive - 70
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
    dvd drive - 18
    = $313.
    Compare that to the Dell computer and decide. You should also note that the power supply does not have a PCI Express connector so you can't add a graphics card later on.
  3. Best answer selected by PC420.
New Build Systems Product
