I bought an H60 and I'm now starting to get afraid it'll leak and spill water all over my 1600 dollar build, how likely are these things to leak.
Also, my case doesn't allow the H60's tubes to be totally straight, they are bent at a 90-ish degree angle(85 degrees/95 depending on how you look at it), is this ok, or will it cause problems.
Thanks!
@Brett, ok, well, I really can't now, any tips on how to minimize the leaking risk?
Thanks.
Thanks!
Thanks.
