Realtek RTL8185 Wireless LAN Utility manual
Hello,
my Realtek won't connect to an open network. It says there's 100% signal strength. it says I might not be able to access the Internet or some network resources. This problem occurred because the network did not assign a network address to the computer. the network point I'm trying to access is from the wireless adapter we have from our desktop computer. I've already tried the repair button. It won't go past the "Renewing your IP address" stage.
9 answers Last reply
More about realtek rtl8185 wireless utility manual
  1. and I have to install this on my laptop, right? Sorry, I'm an amateur when it comes to the technical stuff...
  2. and uhhh, do I download them all?
  3. You only need to download the latest driver that matches your RT8185 and your Operating System
  4. okay. Thank you so much.
  5. okay. I'm so sorry. What exactly do I do with it? Do I need to run anything or does it just need to be downloaded?
  6. once downloaded, you need to extracted/unzip it.
    then there should be a setup.exe file which you should run
  7. Gotcha. Thank you so much, once again
  8. Alright, there's an SYS file but I can't run it.
Configuration Realtek Wireless Lan Wireless Networking
