Will a Phenom II x 6 Cooling Fan work for an FX 6100 Processor?
6 answers Last reply
More about will phenom cooling work 6100 processor
  1. u should check the coolers manufactires site there are all the details all the processors u can use the cooler on
  2. I beleive most of the p2x6's were 125w (not sure about the 1045t) and the fx6100 is a 95w part so yes the cooler will work fine.
    Yeah this CPU Cooling Fan is from a PX6 1100?
  4. Thanks for your help.
  5. Hi :)
    Yes and it will probably cool the cpu better...
    All the best Brett :)
  6. It will work better than a 6100's stock cooler.
    (And it will fit)
    The only thing you don't want to do is install a 95w cooling solution on a 125w CPU.
    -But using a 125W cooler on a 95w chip is actually an upgrade.
Cooling Fan Processors Phenom Components
