I'm building a pc and this is my final list.
Main Hard drive: Western Digital WD30EZRX Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16822136874
Monitors: SAMSUNG B550 Series S27B550V Qty:3 http://www.newegg.com/Product/Product.aspx?Item=N82E16824001553
Capture Card: AVerMedia MTVLIVGHD Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16815100100
Graphics cards: XFX Double D FX797GTDFC Radeon HD 7970 GHz Edition 3GB 384-bit GDDR5 Qty:2 http://www.newegg.com/Product/Product.aspx?Item=N82E16814150632
Power supply: Ocz OCZ-ZX1250W Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16817341046
Card Reader: VANTEC UGT-CR945 Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16820276015
RAM: G.Skill F3-2400C10D-16GTX Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231589
Processor: Intel Core i7-3960X Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116491
Fan (Memory): G.SKILL FTB-3500C5-D Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16835236002
Hard Drive Cooling: Scythe SCIT-1000 Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16835185073
Solid State Drive: Corsair P256GBP-BK Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16820233227
Cooling System: Thermaltake CLW0211 Qty:1 http://www.newegg.com/Product/Product.aspx?Item=N82E16835106183
Operating System: Windows 7 Ultimate austinjohn1999@gmail.com64 bit
I will be using this Pc for Hardcore gaming at the highest quality possible, recording games at the highest quality possible, and live streaming games at the highest quality possible. Are these parts compatible? Are there any other parts you would recommend for what I will be using it for? Also, What Towers Would you recommend? Thanks, Austin.
