Closed Solved
What is the best power supply in this price
Ok so im getting a HIS 777o and it requires a minimum of 500w and i know the horrible Diablotek 500w i have is not going to be enough.. So the card im getting from newegg comes with the two free games and i was going to sell those for about 50-60$ and i was just wondering what is a decent (not amazing gaming quality) PSU to run the card. the card im getting:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161430
So yeah if you can help let me know price range 50-60USD thanks.
Edit: Sorry this is the one im getting not that one
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127687 Also its MSI to sorry
And it needs to be compatible with the Foxconn 2AB1 motherboard.
7 answers Last reply Best Answer
More about what power supply price
  1. Best answer
    This will suffice if your getting the HD 7770 or 7750 (you claimed the 7770 but linked the 7750):
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371045
    I have run the Phenom II X4 955 Black edition and the HD 7770 with the VP-450. In truth, it is not wattage that is most important but the amps on the 12v rail. The HD 7770 should have a power supply that has at least 23 amps on the 12v rail (doesn't use 23 amps for the video card alone but for the whole system).
  2. That's a 7750 not 7770, as for the psu yes it's terrible but for a 7750 or even 7770 it will do.
    Those cards don't even pull more than 100w full load.
    http://tpucdn.com/reviews/HIS/HD_7770_iCooler/images/power_maximum.gif
    http://tpucdn.com/reviews/HIS/HD_7750_IceQ_X/images/power_maximum.gif
  3. Even if its a Diablotek and is capable of powering on the system, I personally wouldn't use it, it is a tier 5 power supply in this list:
    http://www.eggxpert.com/forums/thread/323050.aspx
    Tier 5 should be avoided, though do realize this list was created by a person not some power supply company so it is opinion. Though they did a really good job with it.
    Edit: Looked around and the HD 7770 uses around 12 amps for itself, either way you are golden with that VP-450. You got some room to OC if desired.
    Yeah this looks great thank you.. also i edited the error i now have the 7770 which i also thought was an HIS when really it was MSI (geez i feel stupid lol)
  5. Best answer selected by ohyes247.
Power Supplies Components Product
