G
Guest
Guest
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=719187 This is my case
I need to buy a good heatsink that is better than the crappy stock cooler and I want to buy the cooler master hyper 212 since it fits my budget restrictions. I am concerned however if it may not fit my case or press on my RAM. Can anyone help me figure out whether it will fit or not? if it doesn't then what other heatsink can I buy to replace the crappy intel stock heatsink keeping in mind that I can budget restrictions?
