Hello.
I'm going to make this short and sweet. A while after buying my Hp dv6 with an amd 6770m gpu I decided to update the drivers to the guru 3d 12.4 mobility (64 bit) ones.
Now these drivers where amazing for running mass effect 3. I could run it at 50-60fps on the highest settings at a decent resolution but BF3 had the "Display driver has stopped working and has recovered issue"
I went out of my way in am attempt to fix this issue, and this is where it gets fuzzy. I don't remember what I did but now with the 12.4 drivers (And all drivers before that too I think) My gpu doesn't perform better when plugged in to an external power supply like it used to.
Like before when I was un plugged I got 30-60 fps with an average of 40 but when plugged in I got 60. But now I just get the the former and when I plug and unplug the power supply in mid game it makes no difference whatsoever. It's like the gpu thinks that it's not plugged in.
I have no idea what is causing this and I have tried Everything to fix it. I even resorted to a system restore but that didn't help.
Oh and If I swith the graphics to fixed mode in the BIOS and change any power play settings there my ganme drops down to 4fps.
And in msi afterburner I can't see or adjust the voltage or power limit. It's like the gpu is running off space magic or something.
Help!
Help!
