Intel 2011 w/Corsair Dominator mmy needs CPU cooler help!
Hello, I recently started a new build
N82E16820227792 SSD 256G|OCZ VTX4-25SAT3-256G R 1 209.99
N82E16813131801 MB ASUS|SABERTOOTH X79 X79 LGA2011 1 319.99
N82E16819115229 CPU INTEL|CORE I7 3820 3.6G 10M R 1 299.99
N82E16814130787 VGA EVGA|02G-P4-2678-KR GTX 670 RT 1 409.99
N82E16820233228 MEM 4Gx4|CORSAIR CMP16GX3M4X1866C9 1 144.99
N82E16817139015 PSU CORSAIR| CMPSU-850AX 850W RT 1 189.99
Im really satisfied with it, however I still am lacking a cpu cooler. I dont want to go water cooling as I am not currently planning on overclocking, however, if there is a simple water cooled solution that wont break my bank (100$ MAX) Id be open to suggestions. Ideally id want to pay less than 60 dollars with shipping.
Ive got the Asus Sabertooth x79 with Corsair Dominator x4 memory.
I need a reliable socket 2011 cooler thats not going to interfere with the memory because ive been told that this memory has rather large heat fins.
I should also note that I am using a CoolerMaster HAF 932 case. The case seems large enough to hold any size cooler from what I can tell.
Does anyone have some solid suggestions that i can buy from an E-tailer and not have to worry about it not fitting?
Thanks in advance for any suggestions given!
4 answers Last reply
More about intel 2011 corsair dominator cooler help
  1. I don't think there is.
  2. The Noctua D14 is an awesome air cooler, and even has better performance than some liquid coolers. You could get the H100 or H60 liquid coolers, but they are beat by the D14.
  3. http://www.newegg.com/Product/Product.aspx?Item=N82E16835103176 $63.99 FREE SHIPPING
    Cooler Master TPC 812 RR-T812-24PK-R1 120mm Sleeve with Dual Vertical Vapor Chamber TPC 812 CPU Cooler Compatible with latest Intel 2011/1366/1155 and AMD FM1/AM3+
    http://www.frostytech.com/articleview.cfm?articleID=2654 <----- review of that CM cpu h/s @ Frosty Tech
    http://www.frostytech.com/top5heatsinks.cfm <----- that same CM cpu h/s on Frosty Tech's Top 5 list
  4. I am not sure any of those recommended would work with my mainboard/memory combination
New Build Corsair Dominator Cooling Systems Product
