Hi Guys,
I'm building a DIY NAS. I was wondering abt the PSU requirements. I'm a noob (at actually building things, though I understand teh theory ).
Here is the selected hardware:
- Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
- Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157303
- "Intel Pentium G630 2.7GHz LGA 1155 65W" with "G.SKILL Ripjaws X Series 8GB"
- DVD Drive: ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - http://www.newegg.com/Product/Product.aspx?Item=N82E16827135204
- HDD Not decided yet but:
- 4 x WD Red 2TB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822236343,
- or 3 x WD Green 3TB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822136874, or
- 3 x Seagate Barracuda ST3000DM001 3TB - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148844
AND I WOULD BE ADDING MORE LATER, probably bring up the total number to 6 and then replace only on failure.
- Not sure if it makes any difference to power requirements, but I'll be buying a RAID controller card too. Probably one of the cheaper HighPoint RocketRAID 27xx.
- Wireless Adapter - http://www.newegg.com/Product/Product.aspx?Item=N82E16833166054
I had a look at the FAQ thread with a very related title, but my prime confusion is related to the power required for the HDDs, which was far from answered by that thread.
Thanks
Kashyap
Thanks
Kashyap
