Will all these parts work together I NEED MAJOR HELP!!
Last response: in Systems
August 6, 2012 12:02:43 AM
hi iam Very new at all this i need help on the compatibility of all my parts
iam building a pc for extreme gameing bf3, Skyrim, Dirt 3 up to $999.00CA
Useing PC picker (great help) Iam useing only canadian Sites and prices
heres what i got Picked out
CPU
AMD FX-4100 3.6GHz Quad-Core
$109.99
CPU Cooler
Cooler Master Hyper 212 Plus 76.8 CFM Sleeve Bearing
$25.99
Motherboard
ASRock 970 Extreme3 ATX AM3+
$84.99
Memory
G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600
$41.99
Storage
Seagate Barracuda 1TB 3.5" 7200RPM
$79.79
Video Card
Gigabyte Radeon HD 6970 2GB
$249.88
Case
Cooler Master Storm Enforcer ATX Mid Tower
$78.81
Power Supply
OCZ 650W ATX12V
$73.61
Optical Drive
Lite-On iHAS124-04 DVD/CD Writer
$16.93
Operating System
Microsoft Windows 7 Home Premium SP1 (64-bit)
$99.99
Total: $861.97
WILL IT Work Plzz Say YES
More about : parts work major
August 6, 2012 12:05:47 AM
It will work, but Intel is better at your budget.
m
l
August 6, 2012 12:09:25 AM
It will work. BUT if you are spending that kind of money please don't go with amd. Plus the fx series is horrific for gaming. here you can try this build
i5 3570K 3.4GHz - 230$
ASRock Z77 Pro3 1155 ATX - 95$
Corsair 8GB DDR3-1600 - 50$
Western Digital Caviar Blue 500GB 7,200 RPM SATA 6.0Gb/s 3.5 - 70$
Corsair Builder series 500 Watt - 55$
HAF912 Mid Tower ATX Computer Case- 60$
Windows 7 64 bit - $100
Samsung 22X DVD±RW Burner - $17
HIS H687FN1GD Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card 160$
http://www.newegg.com/Product/Prod [...] 6814161389
This build with os=837$ without os = 737
this will get you high settings on bf3 with 50+ fps average. although if you can spend a bit more money i would get this gpu instead http://www.newegg.com/Product/Product.aspx?Item=N82E168...
this will be a much better build then the build you have made....
m
l
August 6, 2012 12:25:42 AM
Which would still be under his budget of $999CA...
m
l
August 6, 2012 12:27:10 AM
yea im just saying its more then 850....
m
l
