??are these parts compatible
Hello I was wondering if these parts were compatible and how I could make them better or cheaper thank you
COOLER MASTER Storm Enforcer SGC-1000-KWN1 Black SECC / ABS Plastic ATX Mid Tower Computer Case ATX PS2 / EPS 12V (optional ) Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119240
Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM 16MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136769
ASUS VK228H-CSM Black 21.5" 5ms HDMI Widescreen LED Monitor 250 cd/m2 ASCR 80,000,000:1 Built-in Speakers Built in Webcam
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236289
ASRock 970 EXTREME3 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157280
EVGA 01G-P3-1466-KR GeForce GTX 560 (Fermi) DS SSC 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130685
SONY Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DDU1681S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118031
CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139028
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMZ8GX3M2A1600C9
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
AMD FX-4100 Zambezi 3.6GHz (3.8GHz Turbo) Socket AM3+ 95W Quad-Core Desktop Processor FD4100WMGUSBX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103996
CORSAIR CWCH60 Hydro Series H60 High Performance Liquid CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181015
Thanks :D
2 answers Last reply
More about parts compatible
  1. yes all of these parts should be compatible but if you wanted to get it cheaper its not a bad idea to get a cheaper case http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233 that wouldn't be bad
    and if you wanted to go slightly cheaper you could get this ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
    and for price get: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 water cooling is uneeded and is expensive
  2. COOLER MASTER Storm Enforcer < Great Case i'm using it right now.Componets and build looks great , keep us posted. :D :D :D
Homebuilt Systems Product
