Color printer won't print in color
Hello, I have an HP printer (fairly new), but it will not print in color. Even put in new print cartridges.
1 answer Last reply
More about color printer print color
  1. is it a bubble jet?
    if so the nozzles get clogged up if they dont get used alot.
    if it has an onscreen display look for Maintenance > head cleaning
    if you google how to clean heads and your make and model you can find step by step instructions
    depending on how long it sat, it could take a few cleanings. after each cleaning do a nozzle check and it will print out boxes to show you how close you are to having it fixed.
Printers Components HP Printers
