Psu choosing please help
I have a question for you guys about psu s
So I'm building a new pc and I'm not sure what case to get (with a psu)
I am going to get:
AMD FX-4170 CPU -
Asus Geforce GTX560 Ti DirectCU II, 1GB -
ASRock 970 Extreme3 AM3+ MB -
Corsair CML16GX3M4A1600C9 16GB Kit (4x4GB) 1600Mhz DDR3
Hitachi 1TB Deskstar 7K1000.D -
And with that I'm not sure how much power I'm going to need and how big of a case either can someone please help me out to find the right case with a psu.
Any type of information is greatly appreciated
thank you.
10 answers Last reply
More about choosing help
  1. A 560ti requires a 500W PSU. To be safe, I recommend a 550W PSU. Try the XFX PRO550W for $75.
    For case, try the Corsair Carbide 400R. You can remove the hard drive cage to improve airflow.
  2. For a system using a single GeForce GTX 560 Ti graphics card NVIDIA specifies a minimum of a 500 Watt or greater power supply that has a combined +12 Volt continuous current rating of 30 Amps or greater and that has at least two 6-pin PCI Express supplementary power connectors.Overclocking of the CPU and GPU(s) will, of course, increase the +12 Volt continuous current rating required depending on the magnitude of the overclock you are trying to achieve. I recommend this combo
    CORSAIR Builder Series CX600 V2 600W ATX12V v2.3 80 PLUS Certified Active PFC Power Supply
    bundled with:
    1x Corsair Carbide Series 500R White Steel structure ...
    In stock.
    $186.98 http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.1020982
  3. Where did you get that from? I always wanted to know where ko888 got that info from.
  4. Here another recommendation PSU:XFX Core Edition PRO550W - Power supply ( internal ) - ATX12V 2.2/ EPS12V 2.91 - 80 PLUS Bronze - AC 100-240 V - 550 Watt - active PFC
    http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=9&ved=0CHoQFjAI&url=http%3A%2F%2Fwww.tigerdirect.com%2Fapplications%2FSearchTools%2Fitem-details.asp%3FEdpNo%3D128715%26CatId%3D4324&ei=_lMfUKzfPM3WiAL6goCQBA&usg=AFQjCNE6ZHse5fkC6YGKuyh8jziuUOFVvw&sig2=xyCRYRjUcFaYzARwRlvtWQ
    Case:Antec Nine Hundred Black Steel ATX Mid Tower Computer Case with Upgraded USB 3.0
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129021#top
    COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119233
  5. "For a system using a single GeForce GTX 560 Ti graphics card NVIDIA specifies a minimum of a 500 Watt or greater power supply that has a combined +12 Volt continuous current rating of 30 Amps or greater and that has at least two 6-pin PCI Express supplementary power connectors."
    Where did you get that info?
    I learn it from him :lol: NVIDIA website look at the specs for whatever card ;)
  7. AH. Is there one for AMD?
  8. Please do. :P
  9. I have not checked yet i bet there is though i should ask him lol
  10. o.k. i don't know him good but i will lol
New Build Cases Systems Product
