Cooling my system.
Thermaltake Frio OCK CPU Cooler vs Asetek 510LC Liquid Cooling System 120MM Radiator & Fan? I`m getting a computer build by them and was wondering about the cooling part. I know almost nothing about water cooling. And a fan would be much more simpler. But would it be at the cost of a higher temp? Could use some help on the matter. Cpu is a I7 3770k, and graphics is a GTX 570. Thx.
1 answer Last reply
More about cooling system
  1. Water cooling would get you lower temperatures, yes. What's the price difference? If CP is charging the same for each, go for the liquid.
Cyberpower Cooling Fan CPUs Systems
