I got my PC parts in on Monday from Newegg and I wasn't able to build it until Wednesday. I did an external build first to see if all the parts were good. I plug everything up and start to plug up the power supply. When I was going to short out the prongs to boot it up I noticed that when I flipped the switch on the power source the fan moved about 20 degrees and stopped, I figured it was nothing to worry about. So i press the 2 prongs in the F-panel and gave it a few secs and nothing happened. I tried one last time and it still didn't boot up. I put my ear up to it and the power source didn't even sound like it was even running. Of course it made the power down sound but turning it on it made no noise. I made sure I was touching something metal frequently while doing this external build and i had everything on a wooden desk so I doubt it short itself out because of me. I had all the plugs plugged in like the 24 pin, the atx slot, and the slot that goes from your video card (why cant I remember the name for that) cable plugged in. Am I forgetting to plug something up or is it just a bad power supply?
Here are the links to my parts involved with this
Power Supply:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159126
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128521
Video Card:
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130629
Power Supply:
Motherboard:
Video Card:
