Rendering Build-Need Help!
Last response: in Systems
This is a build for the performing arts center in my work place.
Approximate Purchase Date: e.g.: ASAP
Budget Range: Don't go way to nuts
System Usage: Adobe CS6 Master Collection, nothing but video rendering
Parts to Upgrade: (e.g.: CPU, mobo, RAM) **Include Power Supply Make & Model If Re-using**
Do you need to buy OS: No
Preferred Website(s) for Parts: Newegg, maybe Amazon
Parts Preferences: by brand or type (e.g.: Intel CPU, Xeon? It needs to be a power house.
Overclocking: No
SLI or Crossfire: Will only be using maybe 2 monitors
Your Monitor Resolution: 1920x1080 more than likely
Additional Comments: (e.g.: They want this spec'd out! Has to have 3 1 terabyte hard drives and 12-16 gigs of RAM
And Most Importantly, Why Are You Upgrading: (e.g. I'm having trouble running game X or my PSU broke)
More about : rendering build
oh and i used enterprise drives because they were only 10 dollars more than the regular ones
if you want to save even more money, you can get a seagate barracuda 3tb for aroud 150 dollars but it only has a 1 year warranty
Ask the community
