Would This Work? Help!!!
I want to upgrade to a 'Galaxy - GeForce GTX 660 Ti 2GB GDDR5 PCI Express 3.0 Graphics Card' ( http://www.bestbuy.com/site/Galaxy+-+GeForce+GTX+660+Ti+2GB+GDDR5+PCI+Express+3.0+Graphics+Card/6651763.p?id=1218771794861&skuId=6651763&st=660 ) and i want to know if it is compatible with this PCU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817159055
Here are some of my other specs:
Processor: FX-4100
RAM: 2 x 4 GB of ram (8GB total)
7 answers Last reply
More about would work help
  1. PSU is big enough although not a recommended brand.
  2. Can you reccomened a PSU?
  3. Get a good quality psu like this :
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817207013&Tpk=xfx%20550w
    Good offer quality/value.
    The card needs 2 x 6-Pin PCI-e ports and this has 1 x 6-Pin and 1 x 6+2-Pin Would this still work?
  5. Yes the 6+2 pin can be used as a 6 pin or an 8 pin
  6. Yes that XFX will work and the 6+2 you only plug in the 6 pin part.
  7. Thanks so much i was confused
CPUs RAM Graphics Cards PCI Express Product
