Yes No
Ads
Tom's Hardware > Forum > Wireless Networking > Range & Connectivity > NetGear Wifi Router problem
Forum Wireless Networking : Range & Connectivity NetGear Wifi Router problem
I have set up a Netgear router in my office. The desktop where I set it up on is running Windows XP (which is required for work purposes using an older version of CISCO VPN). My work laptop runs Windows XP and has no problems. My second laptop using Windows 7 continues to drop connection repeatedly.
My Netgear machine allows for two signals to be broadcast. The higher signal is not picked up at all on Windows 7, but is seen on the Windows XP (which does not drop). Can you advise?
Thank you
Reply to Dragonote
Seems like a problem with your Windows 7 and not your network. Have you tried updating the drivers for your WiFi NIC under Win 7?
Can that Win 7 machine connect reliably to other WiFi networks?
Reply to canadian69
There are 1920 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Dlink dir-600 router problem
By Realbeast, 6 days ago:
In the WiFax router you should turn off the DHCP service and connect its output to the...
Best offers
Top experts
