First build advice
mrtomzzzz
9
Hello every one i am putting together my first gaming pc and would like to know if all the parts will work together and if it will be any good.
case:Cooler Master Elite 331
cpu:Intel Core i5 2550K CPU
cpu cooler: Arctic Cooling Freezer 13 Pro CPU Cooler
gpu: Palit Nvidia GeForce GTX 670 Graphics Card (2GB GDDR5, Kepler Architecture, 3004MHz Memory Clock, PCI Express 3.0, NVIDIA 3D Vision Surround Ready)
mobo:Gigabyte GA-Z77-D3H
psu:Corsair CMPSU-650TXV2UK Enthusiast Series TX650 V2 High Performance 650W
memory:Corsair Vengeance 8GB (2x4GB) DDR3 1600MHz
hdd:Samsung 250GB 2.5 Inch SATA
I was also wondering would i need a better cpu cooler or psu if i got an overclocked cpu at around 4.5 GHz
Hi there pretty nice build you have going there but there are a few suggestions i have your case doesn't have good cable management options it's also made very cheap i suggest you change it also i would change the i5-2500k to i5-3570k and i would recommend you change your cpu cooler to this CPU Cooler:Thermaltake CLP0564 Frio Dual 120mm Universal CPU Cooler - LGA1366, LGA1156, LGA775, LGA2011, AM3, AM2+, AM2. "Received The Overclockers Tech Gold Award"
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6046364&Sku=T925-3046
other than that your build looks solid to me.
