6950 HD power supply question???
Graphics card Authority
You should be fine. What is the rest of your system specs? How many drives and fans is important too. But for a typical system with a 6950 you should not draw more than 350w under heavy load.
Power supply Master
garryburch187 said:
Hello,
is a ocz-450 model #ocz-450 12 U, enough to power this card .... SAPPHIRE 11188-22-20G Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card (OC Edition). I dont over clock my cpu and have two standrad 7200rpm hard drives running. The amp on the 12v is 26. Thanks
I have one in a closet somewhere
Discontinued around 6 years ago, and wasn't all that good to begin with ( A 350 watt Dell psu from the same time period could put 28 amps of it's power on the 12v )
No way I'd run a modern system with it
Ask the community
