Solved
PC Position Problem
Ok so I'm going to make a pc in the next week or so and I was wondering if it is ok to have the computor run on its side. As in I would lay it down as you would say...an Xbox. I have an Asus p8z77-v lk mobo, corsair Vengence 8gb ram, i5-3570k CPU, WD caviar black 1tb HDD, a cooler master haf 932 case, and a Hyper 212 evo CPU cooler.
Thanks in advance,
MaidenBoots
5 answers Last reply Best Answer
More about position problem
  1. Not going to be a problem. It can be oriented pretty much in any direction.
    -Wolf sends
  2. Best answer
    It will be fine, just make sure you dont have any cords that might fall into fans once oriented its side!
  3. Thanks guys!
  4. Be sure to check an answer. ;)
  5. Best answer selected by MaidenBoots.
Homebuilt Systems
